How to select all parcel that faces the main road
  • Apr 24, 2023 11:04 AM UTC
  • 5 replies
  • 91 views
The distance between the road and the plots are not fixed, so we can't use a buffer
Parcel Facing Main road
nielsgerrits
Forum|alt.badge.img+67
One way to do this is:
  • For every parcel, find the closest road. (NeighborFinder, parcels are bases, roads are candidates, find only 1 candidate)
  • Draw the results as lines using closest base x and y and closest candidate x an y. (VertexCreators)
  • Exclude all results where the line overlaps with a parcel other than itself. (SpatialRelator, list, tester.)
  • Apr 25, 2023 10:07 AM UTC
Thanks, Dear, Idea looks to be great but the shortest path to the road might not intersect with other parcels but actually the parcel might intersect as shown belowPlot Intersects
nielsgerrits
Yes, Ill admin it is a challenging problem. I created some sample data and tried a few things but I have not a working solution for now.
geomancer
Forum|alt.badge.img+71
  • Apr 25, 2023 11:59 AM UTC
Maybe it helps to set a maximum distance in the Neighborfinder?
geomancer
  • Apr 25, 2023 12:00 PM UTC
The community can help you better when you provide some relevant sample data.
