How to read and import a zip file directly inside FME without unzipping the zip file.
  • Mar 2, 2021 5:30 PM UTC
  • 133 views
nbeekers
This is needed to send a zip file Base coded with a Soap request.
Someone ??
Thanks Nick
nielsgerrits
Forum|alt.badge.img+67
I think you are looking for the AttributeFileReader.
Edit: Just checked, I have a workspace which uploads a CSV as base64 in a SOAP call. I read it as text, whole file in one feature, use a BinaryEncoder to convert it to base64 and put it in the soap call like:
<Filename>import.csv</Filename>
<Data><![CDATA[@Value(text_line_data_encoded)]]></Data>
</Import>
