How to preserve original geometry after Bufferer
  • Feb 8, 2022 3:09 PM UTC
  • 83 views
I have some polylines that I buffered with Bufferer in order to make some checks.
Once the checks are performed, I'd like to get the original polylines back. I was wondering if I can copy the lines geometry into another geometry attribute and read them after, or maybe some other technique.
Thanks in advance!
Best answer by nielsgerrits
Yes you can. Use the GeometryExtractor and the GeometryReplacer. I use FME Binary, but other encodings will probably work as well.
nielsgerrits
Forum|alt.badge.img+67
  • Feb 8, 2022 4:16 PM UTC
Works perfectly. Thanks Niels!
