How to filter a pointcloud based on min z from DTM
  • Jun 1, 2021 11:56 AM UTC
  • 5 replies
  • 171 views
koenvdw
Forum|alt.badge.img+7
Hi
I would like to filter my pointclouds based on the minZ from a corresponding DTM.
So the height difference in the area's is not that big. Therefore we could use the minZ from the whole DTM. If it can be done to do it for each rastercel, I'm also interested.
I want to use that minZ value to filter/split/test my pointcloud.
I can't seem to find the right transformer to do this.
Like for the pointcloudfilter. I'm feeding it the pointcloud and from the raster(DTM) side an attribute (minZ). The filter won't accept the attribute.
 This is what I have right now:
fme1
Best answer by koenvdw
Hi @kailinatsafe​
I will certainly test that and come back to you.
In the meantime I got a tip from @Jasper Wisbecq​ to use the clipper.
This seems to work.
The workbench looks like this now:
fme1This is before and after:
fme2So it works pretty well.
Thx guys.
kailinatsafe
Forum|alt.badge.img+24
Hello @koenvdw​ , I think you may need to merge the two datasets before sending it to the PointCloudFilter, as FME won't do it automatically. You can use a FeatureMerger before the PointCloudFilter to merge the minZ from the TIFF onto the point cloud. Hope this helps - Kailin.
koenvdw
  • Jun 3, 2021 4:54 PM UTC
Hi thx for your response.
I tried the feature merger, but based on what do I join?
They don't have anything in common.
Spatialfilter also doesn't work.
kailinatsafe
Hello @koenvdw​ , anytime! Hm.. I think in the FeatureMerger, you should be able to set Requester and Supplier values to 1 for an unconditional merge. Let me know if this works - Kailin.
koenvdw
  • Jun 3, 2021 9:23 PM UTC
Hi @kailinatsafe​
This seems to work.
Thx guys.
koenvdw
  • Jun 3, 2021 9:56 PM UTC
Hi @kailinatsafe​
This seems to work.
Thx guys.
I tested the unconditional merge with the feature merger.
It also works and it was 15 seconds faster.
Also strange, there is a difference in total points and thus also in filesize.
The differences are not visible to the eye.
clipper method result: 4min29 - 56888763 points - 1999997KB
feature merger method result: 4min16 - 56902395 - 2000476KB
So there you have it, to working solutions 😃
