How to draw specific symbol instead of colored point in pdf output
  • Nov 9, 2021 12:53 PM UTC
  • 70 views
gogopotter90
Forum|alt.badge.img+14
i would like to put symbol instead of point in pdf but i have used pdf styler and it has no symbols . do we have transformer that include symbols to define some points in pdf output
fme 2018 .thanks in advance
Forum|alt.badge.img+63
No, there is no such transformer.
Based on the questions you're asking I get the impression you're working on a big project. Could you give us a more complete overview of what you're trying to achieve so that we may be able to help you better?
It sounds like you're trying to make (a lot of) maps, if that's the case one option to consider may be to use the FME Auto plug-in for MAPublisher. In that case you'll be using the styling options of MAPublisher, a plug-in for Adobe Illustrator.
caracadrian
Forum|alt.badge.img+23
  • Nov 9, 2021 3:45 PM UTC
I guess you could use GeometryReplacer to replace points with symbols as geometry.
But you should first create your symbols, store their geometry in an attribute, join your data with the symbol data, then replace the point.
gogopotter90
  • Nov 9, 2021 4:32 PM UTC
thanks , i have found PointStyler from fme hub , i think it could do the job ,iam still trying it .but i have still another question to learn more about it,how could i create specific shape as symbol .Do you have any idea ?
gogopotter90
  • Nov 9, 2021 4:33 PM UTC
thanks for ur reply i will read about map publisher but it is not my case .thanks for help
