How to deal with json and convert them to attributes to use later at the workspace
  • Feb 18, 2022 12:02 PM UTC
  • 137 views
spiderman
Forum|alt.badge.img+7
How to convert the json to attributes so i can use it later in the workspace
part of json :
    "content": [
            "id": "89732" ,
i have used jsonflattener but i found that i got missing data .
Thanks in advance
FME 2020.2
Forum|alt.badge.img+63
Another one to try would be the JSONFragmenter (I always mix those two up). Try this as query:
json[*][*]
And set it to flatten query results into attributes.
Can you share what you have tried so far?
spiderman
  • Feb 18, 2022 3:14 PM UTC
json[*][*]
Thanks .it is working , this method shows id and other items but i have inside the json content  also"geometry":{"coordinates":[x,y],"type":"Point"}
but i got missing when i want to show coordinates .what should i do ?
It would really help if you could post the full json structure here.
Also... if you have the json in an attribute and want to build the geometry that's in there you can simply use the GeometryReplacer, set it to GeoJSON as geometry type. Assuming whoever designed the structure didn't find a create way of storing the geometry it should work.
