How to Create FGDB features based on given attribute description table?
  • Oct 13, 2023 2:08 PM UTC
  • 54 views
bobo
Forum|alt.badge.img+3
Hi, everyone, I need to create a lot of feature classes in an Esri File Geodatabase. Creating them one by one in ArcCatalog takes too much time, I'm sure that there must be a fast way by using FME, I just don't know how, can someone help me out or give me some hints? Thanks very much.
Here's the attribute description table:
nielsgerrits
Forum|alt.badge.img+67
I do not know of a good way to do this, using FME only.
If I need this, I use arcpy. You could create a script in FME and send that to a PythonCaller, but I think it is a lot of work still.
nielsgerrits
Attached workspace does what you want. It needs work for the different field types but I'm running out of time. Manually run step by step, first create gdb, then create dataset, then create featureclass, then create fields.
