How to connect to the FME Server on the Virtual Maschine?
  • Nov 23, 2021 9:27 AM UTC
  • 9 replies
  • 308 views
mferber
I am trying to complete this trail where it is requested to connect to a FME Server in order to upload the workspace. To try that I started a VM on stringo. But I dont know which FME Server Parameters I have to enter now to connect. Also I would like to access the web interface of the server in the VM but I didnt manage to login, maybe you can tell which login credentials are neccessary?
Cheers,
Merlin2021-11-23 10_28_50-Strigo2021-11-23 10_27_23-FME Server Connection
Best answer by mferber
Just to sum up:
Login to the VM FME Server Webinterface
user: admin
pw: FMElearnings
Connection from a local FME client outside the VM
server URL: http://publicIP (get from: Lab Settings - Machine Info)
authentication: basic
user name: admin
pw: FMElearnings
2021-11-23 13_28_13-Strigo
  • Nov 23, 2021 9:47 AM UTC
Have you tried admin / admin (both user and password)?
mferber
  • Nov 23, 2021 9:55 AM UTC
This would be for the webinterface I guess?
Yes I tried, no success.
itsmatt
Forum|alt.badge.img+48
  • Nov 23, 2021 10:25 AM UTC
Did you get an email with any information on how to access the FME Server via email when you initially set up the VM?
From the doc it looks like the password could be: FMElearnings
with user as admin
Server URL would be wither "http://localhost" or "http://fmetraining" - stick with basic connection.
mferber
  • Nov 23, 2021 11:44 AM UTC
@virtualcitymatt​ : the docs credentials got me into the webinterface on the VM.
But in the FME Workbench Desktop client the resonse to the URL is "HTTP Error" no matter if I choose http://localhost/ or http://fmetraining/
itsmatt
  • Nov 23, 2021 12:07 PM UTC
Where are you trying to access the server from (where is your FME Desktop). If you're trying to connect from the same VM then localhost should work, but it wont work if trying to connect from outside of the VM. There might also be an IP address you can try and use.
mferber
  • Nov 23, 2021 12:17 PM UTC
cheers @virtualcitymatt​ !
To connect from my local FME Desktop client outside the VM:
The public IP displayed in VM was the missing info. Now I can connect to the server.
mferber
  • Nov 23, 2021 12:18 PM UTC
Just to sum up:
user: admin
pw: FMElearnings
user name: admin
pw: FMElearnings
itsmatt
  • Nov 23, 2021 12:24 PM UTC
Just to sum up:
user: admin
pw: FMElearnings
user name: admin
pw: FMElearnings
nice, great - Could be safe need to update that
samatsafe
Forum|alt.badge.img+12
  • Nov 30, 2021 5:10 PM UTC
Hi @mferber​ and @virtualcitymatt​, I'm glad you were able to figure this out. Sorry I didn't reply, I was out of the office last week.
We assume in the FME Academy material that the user is running both Workbench and Server on their own machine or a Strigo lab. In both cases, http://localhost/ will work for accessing Server. I had not considered the scenario where someone would run Workbench on their own machine and access just the FME Server hosted on the virtual machine. @mferber​ is there a reason you are doing it that way? I'd be curious to know. It's possible we could update the instructions, but at this point, I would like to know more about the use case first. Thanks.
