How to combine two X,Y coordinates into single point.
  • Mar 29, 2016 8:13 AM UTC
  • 265 views
I want to .CSV data into Smallword by using FME. In my CSV file ï have coordinates "x y". I want to combine these two coordinates into single point.-->"x,y".
CSV formate Data:
IN FME Workbench:
I want to combine X and Y values into single Attribute.
Actually i tried by using "CoordinateConcatenator"
But i am unable to combine the X and Y values.
With a normal stringconcatenator this should work
Forum|alt.badge.img+54
  • Mar 29, 2016 8:38 AM UTC
Or just an attribute creator will work
@Value(X),@Value(Y)
erik_jan
Forum|alt.badge.img+26
  • Mar 29, 2016 2:21 PM UTC
Do you want both X and Y concatenated in an attribute or do you want a point geometry in SmallWorld?
If you want the point geometry the CSV reader has the option to convert the x and y attributes to a geometry as shown in the image below:
  • Mar 29, 2016 9:44 PM UTC
What Eric and the others said. Other option is VertexCreator transformer. Have a look at this https://knowledge.safe.com/articles/687/using-fme-...
