How to clip 3D solid?
  • Jan 17, 2023 2:34 PM UTC
  • 220 views
lazarlubomir
Forum|alt.badge.img+11
Hi everyone,
please, do you have any idea how to clip elements from solid with no volume?
For example feature like in attachment?
Thanks a lot!
solidLubo
daveatsafe
Forum|alt.badge.img+24
  • Jan 17, 2023 7:11 PM UTC
Hi @lazarlubomir​,
Please use a GeometryCoercer to coerce the solid to a fme_composite_surface, then use a SolidBuilder to rebuild the solid from the surface. It should ignore the overlapping faces when building the new solid.
You may need to add a Deaggregator after the GeometryCoercer to break up the surface into individual faces, but try first without it.
lazarlubomir
  • Jan 18, 2023 8:23 PM UTC
Hi @lazarlubomir​,
Hi @daveatsafe​ , thank You so much for advice! I have tried to apply this on my dataset, but with no success. Please, could You give a try on dataset from attachment? This is IFC file containing one solid feature as I wrote.
Thank You so much!
Lubo
daveatsafe
  • Jan 23, 2023 7:29 PM UTC
Thank You so much!
Lubo
Hi @lazarlubomir​,
I tried using the SolidBuilder process on your IFC data, but it was not able to build a valid solid from the deaggregated faces. There may be a small gap that is causing the failure, but I have no tools to find it.
