How to chose flow based on if data exist in one dataset, if it doesnt exist a point should be created
  • May 11, 2021 8:49 AM UTC
  • 81 views
I got a feature reader that reads in excel data. If data exists i create points from that data. If data doesn't exist i need to create a point myself based on center of a polygon with "centerpointreplacer" transformer.
How can I chose flow based on that scenario? If I can create points from excel then I dont want the centerpointreplacer to run.
Best answer by ebygomm
There is a custom transformer called the NoFeaturesTester. If you send no features into this, it will output a feature via the Noinput port if no feature is received.
You can also use a FeatureMerger in the following way to do the same thing
Capture
Forum|alt.badge.img+54
  • May 11, 2021 9:37 AM UTC
Capture
  • May 11, 2021 9:40 AM UTC
Capture
Thanks I will try this in my workspace.
