How to change the name of a repository on FME server?
  • Mar 27, 2023 7:01 PM UTC
  • 225 views
Is it possible to change the name of a repository on FME server (2022 to be specific)? If so how?
Best answer by david_r
Officially, no. My recommendation would be to download the workspaces, create a new repository and re-upload them there. You can then delete the old repository.
  • Mar 28, 2023 6:28 AM UTC
egge
Forum|alt.badge.img+14
  • Mar 28, 2023 9:20 AM UTC
A name is just a name... You might consider to leave the name as is and only modify the Repository Description.
  • Mar 28, 2023 1:16 PM UTC
Thanks David, this will be my approach. Luckily there are only 2 workspaces in that repository so it should be a quick download and reupload process
