How to calculate line on area percent overlap?
  • Apr 14, 2023 7:44 PM UTC
  • 193 views
esalmagul
I have a case where I need to determine which wells (polylines) belong to which unit (polygons) based on spatial relationships.
I need to be able to know the percentage of those relationship (wells and units) and some key data associated with the unit. I need to determine percent of overlap and produce two outputs.
One to show only the relationships (between wells and units) with the highest percent of overlaps (including their percent overlap value) and an another containing all relationships (between wells and units) and their percent of intersect. Thanks!
danilo_fme
Forum|alt.badge.img+58
  • Apr 17, 2023 11:55 PM UTC
Hi @esalmagul​
Please, could you share your data?
londa
  • Apr 18, 2023 6:04 AM UTC
yes ,could you please share the data so that we can answer your querry.
esalmagul
  • Apr 25, 2023 5:14 PM UTC
Hi @esalmagul​
Here it is! Thanks! Wells are lines and units are polygons. Sometimes the same well crosses multiple units.
esalmagul
