How I can get the lowest elevation of a 3D polyline (Polyline ZM)?
  • Nov 11, 2020 5:09 PM UTC
  • 278 views
alfons
Forum|alt.badge.img+7
Hello,
I have some 3D Polyline (Polyline ZM) of which I am interested in the lowest/maximum height in order to be able to make a further query with this information. All polylines have a different height at each of their vertices. Is there an elegant solution in FME for extracting the min/max height of a line and then attaching it as an attribute?
Thank you very much for your support.
Best answer by ebygomm
You can use a BoundsExtractor to get the minimum z and maximum z value of a line. Delete the names for any of the parameters you don't want
Forum|alt.badge.img+54
  • Nov 11, 2020 5:12 PM UTC
alfons
  • Nov 11, 2020 6:01 PM UTC
Perfect, thanks a lot for the superfast support. It works like a charm
