How do I Limit Traffic Flow in Topology?
  • Nov 9, 2023 9:48 PM UTC
  • 88 views
matthewb
Forum|alt.badge.img+12
I was reviewing the article "Build Topology and Calculate Route Length" and had a question left unanswered. The dataset ends with a fork in the route. How would we set the topology builder to allow traffic from segment A to B, A to C, B to A or C to A, but to not allow traffic from B to C or C to B?
Routing_Question
matthewb
  • Nov 10, 2023 9:52 PM UTC
To continue on with this question. When I run a similar dataset through the topology builder, one of the possible routes is excluded, as it only creates a single from and to node for each edge, where edge A could theoretically have 2 from nodes (B and C).
  • Nov 10, 2023 11:32 PM UTC
Hi @Matthew Boyter​ ,
​If you check Generate List from Input Edges parameter in the TopologyBuilder, every node will have a list attribute which contains information of every connected edge. I think you can use the information to find every path through the node.
topologybuilder-parametersegde-list
matthewb
  • Nov 13, 2023 3:49 PM UTC
Hi Takashi,
I am including a zipped extract of my workbench and some sample data in an FFS.
FME_Simple_Topology
FME_Y
First, I'm starting with a network that ends in a Y-intersection. When it is ran through the topologybuilder, the intersection has 2 nodes.
FME_2_Nodes
When ran through the NetworkTopologyCalculator, one leg of the Y is sent to its own network ID, which causes the ShortestPathFinder not to be able to locate it as a viable route.
FME_Network
I've added a testfilter to show 3 different routes, 2 viable routes and 1 route that shouldn't be allowed. Currently, only 1 of the viable routes is being allowed.
matthewb
  • Nov 13, 2023 5:06 PM UTC
I have identified the problem with my dataset that was causing errors in the TopologyBuilder, so now I can route through all possible combinations, but have not resolved the initial problem on how to forbid routes through acute angles.
