How can multipoints read from FME in the writer plugin
  • Feb 3, 2023 10:26 AM UTC
  • 63 views
pehrs
We have an IFMEFeature from type FME_GEOM_AGGREGATE.
The window "Feature Information" in FME Desktop displays the IFMEMultipoint property with 299 parts of IFMEPoint.
How can we get these multipoints in the writer plugin?
If we call feature->numCoordinates() we got 598 but if we call numParts () or numVertices() we got the correct number of 299.
And if we call feature->getAllCoordinates() we got a list of 598 coordinates, but only 299 of these are correct and the other ones consists of a point with coordinates (1, 1, 0). Where does this point (1,1,0) come from?
The list of coordinates starts with
1,1,0
valid point
1,1,0
valid Point
1,1,0
  • Feb 3, 2023 10:54 AM UTC
You can iterate over the aggregate programmatically. For example, using Python:
parts = feature.splitAggregate(recurse=True)
for part in parts:
    coord = part.getCoordinate(0)  # First coordinate of the part geometry
    x, y = coord[:2]  # Get first two elements
    print('Coordinate at x = {}, y = {}'.format(x, y))
Documentation: https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_feature/fmeobjects.FMEFeature.splitAggregate.html
Refer to the relevant documentation if you're not using Python.
pehrs
  • Feb 3, 2023 11:36 AM UTC
Thank you very much.
It worked.
