How can I work around FME Desktop 2021 when FME can not generate the token ?
  • Jun 24, 2021 4:44 PM UTC
  • 83 views
Hi, I installed FME Desktop 2021 and the Reader from Arcgis Portal can not generate the Token.
I generate the token externally and it is fine
the user an password are fine. I tested with The GIS Administrator who has all privileges and I get the same result.
The connection running the FME a 2020.1 in another machine is fine.
How can make it work?
Thanks.
nielsgerrits
Forum|alt.badge.img+67
You could generate the token in the workspace using a httpcaller and use this token in a featurereader.
hkingsbury
Forum|alt.badge.img+73
  • Jun 24, 2021 8:33 PM UTC
Here's the documentation for the call
https://developers.arcgis.com/rest/services-reference/enterprise/generate-token.htm
goatboyboz
Forum|alt.badge.img+5
  • Jun 27, 2021 10:15 PM UTC
