How can I round numbers in steps of 500 with FME?
  • Jul 27, 2021 8:49 AM UTC
  • 376 views
Dear FME community,
I have attributes which contain numbers with several integers like 5800386.006999999 as values. I would like to round these values in steps of 500. So the number above becomes 5800500. If the value is closer to e.g. 5801000 then it should be rounded to that number. If it is closer to 5800000 then it should be rounded to that. The values can have a lot of decimal places or none. This means the solution should be able to handle any given number.
I am very thankful for any help.
Thank you so much in advance!
Best answer by gazza
Divide the number by 500. Round it to the nearest integer. Multiply by 500.
In the AttributeManager it will look like
@Evaluate(@round(@Value(number)/500,0)*500)
gazza
  • Jul 27, 2021 9:43 AM UTC
  • Jul 27, 2021 11:48 AM UTC
Thank you so much for your help. It works perfectly!
