How can i perform a spatial join of points with many to many (m:n) relation?
  • Oct 27, 2022 8:27 AM UTC
  • 6 replies
  • 171 views
renetschi
Forum|alt.badge.img+4
Hello everyboy!
I got two different point feature classes.
The neighbor finder lets me do the 1:1 and 1:n relation which is fine.
Now i would like to perform a spatial many to many (m:n) relation of the points of the two feature classes but i can't figure out a decent way to do this in fme.
I really appreciate your help!
Thanks a lot!
René
geomancer
Forum|alt.badge.img+71
  • Oct 27, 2022 9:37 AM UTC
Would it help to use the NeighborFinder in Candidates Only mode?
renetschi
  • Oct 27, 2022 12:31 PM UTC
hey!
i am not quite sure.
as far as i understand the neighborfinder, the candidates only mode just turns around the 1:n cardinality to a n:1 cardinality so that many base inputs relate to one candidate input.
or do i get it wrong?
thanks for your reply!
dustin
Forum|alt.badge.img+36
  • Oct 27, 2022 12:50 PM UTC
I would look into the PointOnPointOverlayer with a high tolerance. You could at least configure the list parameter to return attributes of all points within that tolerance.
geomancer
  • Oct 27, 2022 1:13 PM UTC
hey!
I was thinking of something like this.
Many_to_ManyEvery point of dataset A can have 0 or more points of dataset B in the list, and the other way aroud. Does this count as many-to-many?
f.kemminje
Forum|alt.badge.img+11
  • Nov 1, 2022 11:31 AM UTC
increase the number of neighbors to find value in settingincreas neighbours
renetschi
  • Nov 30, 2022 1:27 PM UTC
hey thanks for all your help. i will take a look into it and hopefully my problem will be solved!
