How can I keep fme_dataset in writer?
  • May 11, 2021 3:32 AM UTC
  • 61 views
Nice to meet you all. I appreciate your help.
I could write the excel file with fme_dataset when I generated the workspace immediately. I could find fme_dataset in the user attributes.
workspaceuserattributes_beforeHowever, when i reopened .fmw, the fme_dataset in user attributes disappeared and could not write the field into excel.
userattributes_afterBesides, fme_dataset could not be imported to user attributes and fme_dataset00 would be imported automatically instead.
userattributes_import
nielsgerrits
Forum|alt.badge.img+67
You can find a list of technical attributes in the next tab called "Format Attributes".
  • May 11, 2021 4:29 AM UTC
I have already exposed the fme_dataset in “Format Attributes” but the field still could not be wrote into excel file
Forum|alt.badge.img+54
  • May 11, 2021 8:50 AM UTC
Rename it to something other than fme_dataset if you want to write it as an attribute in your output
  • May 11, 2021 10:10 AM UTC
I have lots of different readers which also store the fme_dataset. Is this method need to connect each fme_dataset to the renaming field one by one? Any automatic method? Thanks a lot!
