How can I give 3d polygons the height of a ground plane?
  • Feb 19, 2023 1:58 PM UTC
  • 97 views
fme_hans
GroundplateHi,
How can I give 3d polygons the height of a base. The ground plane I created with the PointCloudSurfaceBuilder. The 3d Polygons have a z-axis with a value of 0.
See the image, the polygons lie above the base and disappear below it.
tomfriedl
Forum|alt.badge.img+14
  • Feb 19, 2023 5:22 PM UTC
You can use the ​SurfaceDraper. Maybe is nessary to use the Densifier before.
fme_hans
  • Feb 21, 2023 9:23 AM UTC
hi,
I'll check that out. In the meantime I had found another solution. I first made the 3d polygons exaggeratedly large and then you can use a clipper to determine the interface with the ground plate.
