How can I draw wall surface between ground and roof surfaces
  • Apr 24, 2021 9:58 PM UTC
  • 113 views
mahbouberezaiee
Hi. I have read the citygml data and changed wall and ground surface. How can I draw the new wall surface between them(without extrude)?
I need all as surfaces at the end.
Best answer by takashi
Hi @Mahboba Rezai​ , the BRepSolidBoundaryCreator.Beta transformer from FME Hub might help you.
  • Apr 25, 2021 12:34 AM UTC
mahbouberezaiee
Thanks @Takashi Iijima​  . That really helps.
