How can I create HTML File
  • Oct 20, 2022 2:58 PM UTC
  • 97 views
asadamjad
Participant
Forum|alt.badge.img+12
I have a multi-workspace and I want the HTML file with this information
ProductID
WorkSpace Name
Area
TimeStamp with Date
Status (Fail, Pass)
  • Oct 20, 2022 3:06 PM UTC
Have you looked at the HTMLReportGenerator. You can use the Text File writer to write the output to a file.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/htmlreportgenerator.htm
asadamjad
Participant
  • Participant
  • Oct 20, 2022 3:10 PM UTC
I have Multi work space how can I join in one Html file?
asadamjad
Participant
  • Participant
or how can i mention that is work space work success or error and also mention that the error
