hi i use fme for web scrap, when i extract 2 lists (code, price) to write in a excel file, secend list starts after last row of first list. my lists are corresponding and they must be in same row
  • Oct 25, 2021 2:01 PM UTC
  • 72 views
itsmatt
Forum|alt.badge.img+48
  • Oct 25, 2021 5:54 PM UTC
Hmm, there's probably a better way but you should be able to get the element index from the lists when exploding - you can then use a FeatureJoiner and join on this index.
So check your ListExploder settings and make sure that "Element Index Attribute" is set. Set it to something like "_list_index". Then in your FeatureJoiner you can use the "_list_index" attribute as the join key.
hkingsbury
Forum|alt.badge.img+73
  • Oct 25, 2021 7:07 PM UTC
it`s worked, thanks so much 🙏
it`s good idea, but data of products change every day
