Hi! I have a problem with LineBuilder , which I hope you can help me with.
  • Sep 23, 2020 8:13 PM UTC
  • 43 views
dor1411993
printscreenI have a few thousand points for which I need to build a line that connects a point to another point or two, based on location.
For example, if a type A point is far from a type B point at a certain distance, then build me a line that connects them.
Do you think this is possible?
Of course I tried with theLineBuilder and could not reach a desired result.
deanhowell
Forum|alt.badge.img+24
  • Sep 23, 2020 9:30 PM UTC
I would suggest using the NeighborFinder to find the points as this will get you the distance and coordinates to the point and then use the coordinates to add a vertex using the VertexCreator
