Hi how to avoid to repeat 3 days of data read after a translation failed? Seems the temporary folder run out of space. Can I swap the temporary location and restart the process from certain point instead of starting again from the begin? Alex
  • Oct 14, 2021 7:28 AM UTC
  • 5 replies
  • 96 views
alexandreaalves
Best answer by sigtill
Hi @alexandreaalves​ . Turn off "Feature caching" and this should work much smoother. To change the temp folder you can have a look here: https://community.safe.com/s/article/fme-temp-environment-variable
sigtill
Forum|alt.badge.img+25
  • Oct 14, 2021 8:45 AM UTC
alexandreaalves
Hi @Sigbjørn Herstad​ , I am new on it.
How can I turn of the "Feature caching" and is that possible to run this again from a certain point avoiding to loss 3 days importing and combining Point Clouds?
sigtill
  • Oct 14, 2021 10:40 AM UTC
Hi @alexandreaalves​ - this article explains the Feature caching in detail: https://www.safe.com/blog/2018/05/caching-data-fme-evangelist174/
sigtill
  • Oct 14, 2021 10:41 AM UTC
Unfortunately no way to continue this translation when it has stopped, as all the "caches" are now yellow and will be started over again. However it should take a lot less time to process once you have turned off feature caching. Try the workspace with only 2 input files and see that you get the correct outputfiles - then you can run it on all the files afterwards.
alexandreaalves
Really helpful, thank you.
Alex
