Hi everyone, I'm experiencing some issues with Writing e57 file. It comes out in slices (as if each of the point's coordinates were rounded along one of the axes).
  • Jun 24, 2021 1:42 AM UTC
  • 72 views
Original e57 is exported from Recap with appropriatecoordinate system assigned.
Comes out in slices even if I'm just reading and writing file without any transformations. e57 clipped, overlaid with original e57 exported from Recap.Elevation - Slices Visible.Plan viewAnother symptom is that the file size is drastically reduced upon export.
I've just recently started getting into the world of FME, so most probably doing something fundamentally wrong.
Would appreciate any help.
kailinatsafe
Forum|alt.badge.img+24
Hello @valentinbelets​ , would you be able to share a sample file? Also, what version of FME Workbench are you currently using? Best, Kailin.
Hi @kailinatsafe​ ,
Thanks for a quick reply!
I'm using FME Workbench 2021.0.
Not sure I can share a dataset because of our data privacy policy.
