Hello! It seems like that the cursor is misplaced in someway in FME workbench. When i hold the cursor over one window and scroll, it affects another window. fme-desktop-2019.2-b19801-win-x64
  • Feb 11, 2020 3:18 PM UTC
  • 5 replies
  • 144 views
It seems like that the cursor is misplaced in someway in FME workbench. When i hold the cursor over one window and scroll, it affects another window. fme-desktop-2019.2-b19801-win-x64. the server is running windows server 2012 r2 on which FME is installed.
Hi @serhiiivashchen
do you have a high resolution display? If yes, it might be an issue with scaling. In Tools > FME Options > Appearance > Advanced Options, please check Enable automatics scaling for High DPI Displays and restart FME Workbench. This should resolve the problem.
Hi! thank you for an answer. I'm connecting the server via RDP session. "automatics scaling for High DPI Displays" did not help.
HI, just installed FME 19.2 for test purposes on Microsoft Windows 10 Enterprise and it works as it should :-(
Hi @serhiiivashchen
Hi! workbench works fine on windows 10 locally on my laptop. but on windows 2012 r2 scrolling malfunctions. is it something has to do with RDP?
Hi @serhiiivashchen, thank you for pointing it out. This is a known issue (internal reference: FMEDESKTOP-9150) and unfortunately there is no timeline information I could provide with you. Sorry about any inconvenience.
