Hello, I am new to FME desktop, I make a workspace to compare data between agol feature line attributes and an excel file on my device, then I tried to update the changes on agol feature.
  • Oct 22, 2022 4:52 PM UTC
  • 81 views
The error i received is
Forum|alt.badge.img+63
The error message states that there's one or more features without a coordinate system being written and the AGOL writer does not like that.
If you know what coordinate system your data is in you can use a CoordinateSystemSetter to specify that.
  • Oct 23, 2022 5:53 PM UTC
You are right, i placed a coordinate system to the excel file and it works perfectly, although its a little strange to assign a coordinate system for table, however, it works 😃
thanks alot
thanks alot
It does make sense actually. Excel is a non-geographic format. The coordinates stored there are just meaningless numbers. But when you want to perform spatial analysis on it, or write to a geographic format, you do need to tell FME what those numbers mean.
