Hello community, I have two polygones. One with smaller areas and the other with bigger ones. The vertices of the bigger areas should align with the vertices of the smaller polygones. What is the easiest way to do that?
  • Mar 26, 2021 1:11 PM UTC
  • 54 views
I tried with chopper, buffer and PointOnAreaOverlap but I don't manage to modify the polygon. Due to the accuracy problems and different sources the vertices are close to about 1-2cm. How to modify the big polygon to the vertices of the small one automatically? Thank you for help!!
Best answer by caracadrian
Try Snapper/AnchoredSnapper or AreaGapAndOverlapCleaner with tolerance set to include your known vertex distance.
caracadrian
Forum|alt.badge.img+23
  • Mar 26, 2021 1:41 PM UTC
  • Mar 26, 2021 2:21 PM UTC
AnchoredSnapper is exactly what I was looking for...thank you caracadrian!!
