Has the Geocoder transformer been removed from FME Desktop 2021?
  • Oct 21, 2021 7:19 PM UTC
  • 218 views
I noticed that when I went to add the Geocoder transformer to a workbench there no longer was a transformer called Geocoder. I am using it to connect to an ArcGIS Server Rest geocoding service. I saw a Geocoder ArcGIS Online transformer and other system specific Geocoder but not the original "Geocoder" transformer.
Best answer by andreaatsafe
Hi @jasonclemis​ ,
Can you check the exact build number you are using? I believe you might be using a beta of FME 2021.2.
In FME 2021.2 and newer, we have replaced the Geocoder transformer with an FME Hub package transformer. This replaces the previous Geocoder transformer that was shipped with FME 2021.1 and older.
-Andrea
andreaatsafe
Forum|alt.badge.img+17
  • Oct 21, 2021 8:27 PM UTC
Hi @jasonclemis​ ,
-Andrea
Thanks, I will check it out. I ended up using the HTTP caller with some of the JSON transformers and it seems to be much faster than the previous Geocoder transformer
hwilson
Forum|alt.badge.img+4
  • Mar 23, 2023 7:42 PM UTC
@jasonclemis Hi I was wondering if you could share your work around for the geocoder transformer. I am having issues with the new geocoder package from the hub. The old geocoder transformer worked great.
