Has anyone had the issue with 'fmepy_emailer'???
  • Oct 11, 2023 7:10 PM UTC
  • 203 views
shawn.brandt
I'm having problems with the "fmepy emailer"....
  • Python Exception <ModuleNotFoundError>: No module named 'fmepy_emailer'
  • PythonFactory failed to load python symbol `fmepy_emailer.Emailer'. An outdated FME packaged transformer may be in use. Please check Tools > FME Options > FME Packages to confirm that all FME Packages are up to date
  • Factory proxy not initialized
  • Emailer_CALLER (PythonFactory): PythonFactory failed to process feature
New to FME Flow... TIA for your help!!!
nielsgerrits
Forum|alt.badge.img+67
In what context do you get this error? Sounds like you have an issue with with the Emailer transformer? This is a package nowadays which you can update / reinstall. Tools, Options, FME Packages, select Emailer, try update / remove / reinstall.
