Good morning, I have recently started working with FME with no previous experience with the software and was wondering would anyone be able to me how I fix this problem please and what does it actually mean? Many thanks Andrew
  • Dec 4, 2020 10:44 AM UTC
  • 178 views
FeatureJoiner_2_<Rejected> (TeeFactory): FeatureJoiner_2_<Rejected>: Termination Message: 'FeatureJoiner_2 output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature
davtorgh
Forum|alt.badge.img+12
  • Dec 4, 2020 10:56 AM UTC
Hi @andreweastop​ ,
this is typically a problem due to an absence of a join key in some features. If this is the case, use a Tester before the FeatureJoiner to filter out features without join key value.
screenshot.1
Anyway, you can inspect the rejected feature in the Data Inspector (there should be an attribute added by the FeatureJoiner containing an explanation).
Hope that helps!
Thank you very much
alexlynch3450
Forum|alt.badge.img+16
to add, if you want to bypass terminating the translation:(see image). Would not recommend this setting for master or published workspace though. Screenshot 2020-12-04 082330
thank you Alex
