GML conversion not working properly in FME desktop 2019.
  • Oct 25, 2019 6:03 AM UTC
  • 6 replies
  • 97 views
I'm trying to convert a gml file to cesium 3d tiles.I got the output but unable to view the content in cesium.Its zooming to wrong place.I inspected the data in FME data inspector i'm able to view in 2d properly but unable to view in 3d, i'm able to see just lines.
I have attached the screenshots and gml file.What wrong i'm doing.How to resolve this.
Forum|alt.badge.img+63
Your x and y coordinates are in lat/lon so FME is likely interpreting the z values to be in degrees as well, which results in buildings several miles tall. If you reproject it to a non lat/lon coordinate system (I would try the relevant Missouri State Plane) it should hopefully look a lot better.
itsmatt
Forum|alt.badge.img+48
  • Oct 25, 2019 10:35 AM UTC
Your data works for me in our cesium application (although the buildings are inside out (See below) - Perhaps the configuration of your Cesium application is not quite right.
  • Oct 28, 2019 9:27 AM UTC
But how to make them project correctly.I cant even see the buildings in my application.Can u share any workspace to covert this gml
itsmatt
  • Oct 28, 2019 9:54 AM UTC
It was literally reader to writer, no reprojection, they are already projected correctly as far as I can tell. I would suggest you check out the cesium documentation. If you want to save some time and work with a great company who can host your city model for you in cesium check these guys out: https://www.virtualcitycloud.de/en/ - what a cool fun bunch of people ;-)
  • Oct 28, 2019 3:57 PM UTC
I have done both kinds of conversions with and without reprojection. But still same thing tileset is not visible. Unable to find the reason. I'm using cesium 1.62 version and latest chrome version.
  • Oct 28, 2019 4:00 PM UTC
Thanks for the reply i tried what you have said.I reprojected the gml to missouri state plane.Able to see the 3d view of gml but with some distortion.But still unable to view the tileset in cesium.
