FMELine.appendLine in PythonCaller
  • Dec 25, 2023 10:26 AM UTC
  • 47 views
When I was trying to add the line to the existing line using PythonCaller FMELine.appendLine(feature.getGeometry) then it is closing the paths as polygon. Basically it is adding an extra segment and closing the path.
In the below image selected line, there is a straight line created when I use the above function.
What's this worst calculation? Who is the coder for this?
  • Dec 25, 2023 2:17 PM UTC
Hi @kanthsri74​ ,
I don't think "FMELine.appendLine(feature.getGeometry)" is executable. Can you please post a script which can be run and also reproduces the problem?
