FMEJoiner
  • Nov 4, 2021 12:07 AM UTC
  • 10 replies
  • 124 views
fme_can_do_it
Forum|alt.badge.img+13
I am using FME joiner to join tables. the joined tables do not show all fields from the source table. I was wondering what could be the reason. Any help would be greatly appreciated.
Best answer by redgeographics
i have some attributes with the same name like UDF1 and UDF 2in both layers, but the joined table only gives me one set of these attributes, i have to actually transfer these attributes from one feature to another.
Right, you have the FeatureJoiner set up so that in case of attribute conflicts it'll take the ones from the "Left" input. So it's working as intended. If you want to keep both sets you should take the data flowing into the "Right" input and rename those attributes, e.g. via a BulkAttributeRenamer where you select those attributes and prefix or suffix them.
hkingsbury
Forum|alt.badge.img+73
  • Nov 4, 2021 2:52 AM UTC
Hi, are you meaning the FeatureJoiner? That should auto populate all attributes present in your inputs
Forum|alt.badge.img+63
Can you share a screenshot of your workspace and the settings of the Joiner? Is it actually a Joiner and not a FeatureJoiner like @hkingsbury​ mentioned? The Joiner was phased out many years ago.
fme_can_do_it
  • Nov 4, 2021 12:34 PM UTC
I am using FeatureJoiner to join tables. I am attaching some screenshots of the workspace.
So which attributes are not coming out of the FeatureJoiner?
fme_can_do_it
  • Nov 4, 2021 12:43 PM UTC
fme_can_do_it
  • Nov 4, 2021 12:48 PM UTC
that makes sense to me, I'll give it a try. Thank you so much!
fme_can_do_it
  • Nov 4, 2021 1:13 PM UTC
that worked! thank you!
You're welcome!
fme_can_do_it
  • Nov 4, 2021 1:15 PM UTC
thank you for your help!
