FMEaggregate cannot be converted to esriGeometeryPolygons error issue
  • Oct 19, 2022 7:34 AM UTC
  • 206 views
edward_skanska
HI there
I am alittle confused by this error as I am writing several shp files into AGOL, I am using the same area for clipping the data which is aggregated into one area using the tools you can see below.
On the other shps file I am writing I have no ran into this issue, they are fine to upload etc but on the last couple of shp files this is the error I am getting.
I was wondering if anyone had seen this before? I am not trying to write the area used for clipping to AGOL, but just the output of the data which is clipped, so im not 100% sure why im running into this error.
Forum|alt.badge.img+54
  • Oct 19, 2022 8:50 AM UTC
Have you checked that your aggregate only contains polygons?
edward_skanska
Hey again
As far as I can tell it only contains Polygons
  • Oct 19, 2022 9:58 AM UTC
Hey again
The error is in the writer, so you need to look at the features you have after they have been clipped.
You could do this by deaggregating after the clipper and then using a geometry filter or looking at the feature with the feature information window to see what the aggregate is made up of
e.g.
edward_skanska
Hey again
Ahh amazing thank you
I was fiddling with the tools you reccomended, and thought id just using the deaggregator and its worked now.
