FME Server Unable to find a Microstation Installation
  • Mar 10, 2022 1:57 PM UTC
  • 52 views
We have a pipeline that is reading .dgn files, it seems to be working fine on a local machine where we actually have Microstation installed but once we deploy it on the server we are getting this message:imageIt creates some output, the pipeline is not failing but the output on the FME Server is almost half as big as locally and has missing features.
So my question is: Is this a bug or what's causing this? Because I was under the impression that FME does not require additional software.
Our FME Server is hosted by us, not on FME Cloud if that matters.
Thank you in advance!
daraghatsafe
Hi @edidimand​ , what build of FME Desktop and FME Server are you using?
