FME Server is trying to get to a zipped file geodatabase
  • Apr 4, 2020 9:14 AM UTC
  • 6 replies
  • 103 views
felipeverdu
Forum|alt.badge.img+12
Hi
I keep getting this error while my workbench in FME Server is trying to get to a zipped file geodatabase.
748Unable to connect to the File Geodatabase at 'C:/ProgramData/Safe Software/FME Server///resources/data//_Automatiseringar/DATA_GEOPIPE_GEOPARK.gdb.zip'. Make sure the correct filename was specified, and that the geodatabase wasn't saved with a newer version of ArcGIS than the one installed locally. The error number from ArcObjects is: '-2147024893'. The error message from ArcObjects is: {}747Installed ArcGIS version is '10.7.1'746An ArcGIS license is already checked out. The product checked out is 'Advanced'745Opening the Geodatabase reader744Notice - Performing envelope query on the `GEODATABASE_FILE' reader, post-filtering spatial predicate in FME743Performing query against GEODATABASE_FILE dataset `C:/ProgramData/Safe Software/FME Server///resources/data//_Automatiseringar/DATA_GEOPIPE_GEOPARK.gdb.zip'
I am not sure how to handle this. Even though I point to the right zipped file in the proper resource folder is still complaining.
Help!!!
Br,
Felipe Verdú
itay
Forum|alt.badge.img+19
  • Apr 5, 2020 10:39 AM UTC
Could it be that the user running the workspace doent have the right permissions to access the gdb?
felipeverdu
  • Apr 7, 2020 7:21 AM UTC
Hi @itay
That could be the reason, but I have tried to give the right permission to access the gdb but it doesn't work quite well...
Thx anyway for your words!
Br,
Felipe Verdú
itay
  • Apr 7, 2020 9:26 AM UTC
Hi @itay
Br,
Felipe Verdú
Hi @felipeverdu1,
Can you specify why it is not working? and what permissions are set ?
felipeverdu
  • Apr 7, 2020 9:50 AM UTC
Hi @felipeverdu1,
Hi again @itay
I think I finally solved it throught restart of services (FME Server). I needed to this several times and this is weird...but I think it is working now.
Br,
Felipe Verdú
jordimonk
  • Aug 7, 2020 5:12 PM UTC
Hi @felipeverdu​
I had been getting the exact same error message. The workbench worked fine in Desktop, but then failed with that message in Server. I was pulling my hair until I accidentally looked at this line (Desktop log):
'0.2|INFORM|Connected to the File Geodatabase at 'C:\\Users\\<myUserID>\\AppData\\Local\\Temp\\FME_TempFileStore_1596819757681_29032\\dsGEODATABASE_FILE_4_1596819757682_29032\\MB_Facilities_HighPressurePipeli_1596819757682_29032\\MB_ENHHPL_GDB_LL83.gdb', which somehow looked to me as a quite long string.
The name of the zipped geoDB I was providing was 'MB_Facilities_HighPressurePipelines_IHS.zip'. The name of the workbench, FWIW, was also quite long: 'HS_FacilitiesHPPipesLPPipesGasFranchiseAreas_BCABSKMB_2_FileProcessor.fmw'.
In my case, simply shortening the name of the ZIP geoDB to 'MB.zip' made it finally work in FME Server.
As I see it, in my particular case at least, it was simply a matter of FME Server enforcing some max. string length rules and truncating the resulting file location string. Once I shorten some of the strings used internally by Server to build the file location, everything works.
felipeverdu
  • Aug 21, 2020 11:22 AM UTC
Hi @jordimonk​
Thanks for your comment. I believe we solved the problem enabling long file path support. See the link below.
https://community.safe.com/s/article/windows-enable-long-file-path-support
Br,
Felipe Verdú
