FME Server can not add network drive as new resource
  • Feb 24, 2022 3:11 PM UTC
  • 297 views
The account that is used to run FME Server models has access to a network drive (\\\\srv-be-di-xxxx\\fs-data\\). Files can be read from and output can be written to this network drive without issues, using the right paths as parameters to run the model. However, when I try to add this network drive as a new resource in the Resources tab of the FME Server UI, I get the notification:
Error. The settings for this Resource Connection are invalid. Do you still want to save
Path does not exist: \\\\srv-be-di-xxx\\fs-data\\
Why is FME Server able to use this network drive in the models, but not to actually add it as a new resource?
Best answer by hollyatsafe
Hi @Bert Akkermans​ ,
For workspaces to read/write from a network path the FME Engine Service needs to be running under the service account with the correct permissions, but for it to be added as a resource connection both the core and web application server service also need to be running under this account, can you double-check that all three services are using the service account?
If you're installation also uses the default FME postgres database this can be left running as local system.
  • Feb 24, 2022 5:35 PM UTC
vhruska
Forum|alt.badge.img+7
  • Dec 30, 2022 4:18 PM UTC
Holly,
I'm having the same issue.
How would I check which accounts services are using?
Is there a detailed guide you could point me towards?
gisbradokla
Forum|alt.badge.img+27
  • Dec 30, 2022 7:41 PM UTC
Holly,
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Running_System_Services_Under_Different_Accounts.htm
If you look at the services on your server machine
services
