FME Inspector doesn´t open
  • Feb 13, 2020 2:16 PM UTC
  • 374 views
terezia86
since my new update to FME 2019.2 opens the FME Inspector not automaticly.
I can open it from "Visual Peview"
Any Idea what to do?
Best answer by redgeographics
In Tools -> FME Options -> Workspace there's a setting to open the Data Inspector when the Visual Preview window is closed, that's the way to do it.
Inspection has been moved into the FME Workbench starting in 2019.0, combined with feature caching it gives you a lot more options for inspecting the flow of your workspace.
Forum|alt.badge.img+54
  • Feb 13, 2020 2:20 PM UTC
Is the following box ticked in FME options "Inspect with Data Inspector when Visual Preview window is closed"
Forum|alt.badge.img+63
erik_jan
Forum|alt.badge.img+26
  • Feb 13, 2020 2:28 PM UTC
The Tools option is the solution, except when you run the workspace from a batch file.
For that missing option an Idea is posted here
terezia86
  • Feb 13, 2020 2:48 PM UTC
Thanks a lot, it has worked!
