FME Desktop Build 22304: The fme workbench has “parsing error”,
  • Mar 25, 2022 6:53 AM UTC
  • 83 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out why the fme workbench has “parsing error”. As I open it, all the transformers are deleted. fortunately, I could restore it from the backup
What could be the issue here?
Clip_304
Forum|alt.badge.img+63
Are you using special characters, like €, in attribute, feature type or transformer names?
What you can try is open the .fmw file in a text editor and search for that character, then replace it with something that's not a special character. Make sure to save it under a different name though! Then try open that in Workbench.
mark2atsafe
Forum|alt.badge.img+59
Can you maybe create a support case and send the workspace file to us? If FME created a file we ought to be able to open it again. I think we'd also be interested to know what locale your computer is using.
jamal
  • Mar 26, 2022 6:59 AM UTC
Unfortunately, I didn’t keep the corrupted file. However, this is the first time ever I got an fme file corrupted.
The message is irrelevant as I didn’t use the symbol indicated
