FME Desktop: Attributes fails to be transferred to a file geodatabase,
  • Jan 15, 2022 8:59 AM UTC
  • 164 views
jamal
Forum|alt.badge.img+5
In the screenshot below, I wanted to write the result of the “geometry filter” into a file geodatabase having all fields transferred. However, the indicated fields are not transferred.
What could be the issue here?
The data and workbench are attached
Clip_85
Clip_84
Best answer by daveatsafe
Hi @jamal​,
The attributes starting with 'fme_' are generic format attributes, and are generally mapped to the same generic format attributes on the output feature, rather than to the user attributes of the schema. If you want to use this information in the output schema, I recommend using an AttributeCopier to copy them to attributes without the 'fme_' prefix.
daveatsafe
Forum|alt.badge.img+24
  • Jan 20, 2022 7:26 PM UTC
Hi @jamal​,
jamal
  • Jan 24, 2022 8:00 PM UTC
Thank you for the help. It works fine
Clip_119
Clip_120
