FME Desktop 2020: How to count the number of dissolved polygons and store them in a field?
  • Nov 24, 2021 11:58 AM UTC
  • 107 views
jamal
Forum|alt.badge.img+5
For example, in the screenshot below, I wanted to create a field that stores the the number of dissolved polygons.
How this can be performed?
Clip_1207Clip_1208
Best answer by nielsgerrits
You can do this by typing an attributename you need in the field "Dissolve Count Attribute". See the documentation:
The attribute identified by this parameter will store the number of input polygons dissolved into an output polygon.
For example, if 3 input polygons dissolved into 1 polygon, then that 1 polygon would have this attribute set to 3.
nielsgerrits
Forum|alt.badge.img+67
  • Nov 24, 2021 12:03 PM UTC
jamal
  • Nov 24, 2021 12:22 PM UTC
Thank you for the help. It works fine
Clip_1209
