FME Desktop 2020: FME appears to mistranslate the content of AutoCAD dwg file,
  • Nov 22, 2021 6:13 PM UTC
  • 5 replies
  • 146 views
jamal
Forum|alt.badge.img+5
In the screenshot below, I couldn’t figure out how the FME creates the marked square while it’s not physically existing in the AutoCAD drawing file.
What could be the issue here?
The CAD file is attached
Clip_1179Clip_1180Clip_1181
Clip_1182
itsmatt
Forum|alt.badge.img+48
  • Nov 23, 2021 10:17 AM UTC
This is preeety weird - given that it has an entity handle id I assume that it is somewhere in the file. Just hidden or not correctly stored. I think @andreaatsafe​ should pass it along to the dev team to see what's going on.
I also uploaded it to Autodesk free online viewer and couldn't see the little box.
I've seen stuff like this before where there are boarders with different scales that do not behave as expected outside of autocad. There are also a number of boxed on the 0 layer which could be related somehow.
jamal
  • Nov 24, 2021 7:32 AM UTC
Thank you for the input. It would be great if an expert can dig deeper on this and find out what the issue is
itsmatt
  • Nov 24, 2021 7:33 AM UTC
Do you know which tool initially created the data? was it authored in AutoCAD?
jamal
  • Nov 24, 2021 7:37 AM UTC
This is how my agency received the file from the source. No idea about the licensing issues in the source.
jamal
  • Jan 29, 2022 7:46 AM UTC
This is a very complicated issue in AutoCAD!
For example, in the screenshot below, if the content of the dwg file is selected with the (ctrl + A) then it shows objects that are not visible before the selection (knowing that all layers are turned in both cases)
Not sure how FME could catch such errors and fix them
The dwg file is attached
Clip_154
Clip_155
Clip_156
Clip_157
