FME changes a number (0.8) (SQLExecutor) into a string (windows-1252) and results in a error.
  • Dec 22, 2021 7:38 AM UTC
  • 106 views
This is the error message:
The database generated an error while attempting to convert the string `0.8' to an OCINumber, so alternative number parsing was performed. (serverType=`ORACLE8I', serverName=`****', userName=`*******', password=`***', dbname=`')
It doesn't matterhow you cast the number in the sql query.
@j.brugge​ I couldn't reproduce your issue. I've attached an example workspace that perhaps you can try and manipulate to replicate the problem. Or attached a simplified version of your data and SQL. Also let us know what version of FME you're working with. This example is FME 2021.2
  • Dec 23, 2021 8:06 AM UTC
@Mark Stoakes​. Since i'm new here I also made a 'case'. I'm not familiar with the basic community rules. So maybe i'll wait for the answer on my case and I'll post it here?
I'm using FME(R) 2021.1.1.0 (20210730 - Build 21619 - WIN64).
--SQL to fill database
select
  CAST ('0.8' as varchar(3)) as "CASTASVARCHAR",
  cast (0.8 as number) as "CASTASNUMBER",
  0.8 as Zonder
from dual
--SQL to create table test
Create table test
 DWH_ID number GENERATED by default ON NULL AS IDENTITY,
 CASTASvarchar VARCHAR2(3),
 CASTASNUMBER number(2,1),
 Zonder number(2,1),
 DWH_STARTDATUM   DATE,
 DWH_MUTATIEDATUM   DATE default sysdate not null,
 CONSTRAINT test_PK PRIMARY KEY (DWH_ID)
GRANT SELECT, INSERT, UPDATE, DELETE ON test TO DIENSTVERLENING_ETL;
GRANT SELECT ON test TO DIENSTVERLENING_REPORT;
COMMENT ON TABLE test IS 'TEST';
commit;
  • Jan 3, 2022 8:47 AM UTC
It might be a locale issue. Perhaps try using a StringReplacer to change "0.8" to "0,8" before the SQLExecutor and see if that helps.
