FME 2022.1 Tester-Failure
  • Jul 11, 2022 1:54 PM UTC
  • 9 replies
  • 204 views
vki
Forum|alt.badge.img+8
We just updated to 2022.1 and now I'm getting an error when using the Tester.
That's what I did:
I  used a Creator and created an attribute "attr1" with the value 5 in an AttributeManager.
Now I add a Tester with "attr1 = 5" then I get this error:
Tester (TestFactory): The clause 'TEST { @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>attr1<closeparen>,Tester) = 5 ENCODED }' within 'FACTORY_DEF * TestFactory FACTORY_NAME Tester INPUT FEATURE_TYPE AttributeManager_OUTPUT TEST { @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>attr1<closeparen>,Tester) = 5 ENCODED } BOOLEAN_OPERATOR OR COMPOSITE_TEST_EXPR <Unused> FEATURE_TABLE_SHIM_SUPPORT Yes PRESERVE_FEATURE_ORDER PER_OUTPUT_PORT OUTPUT PASSED FEATURE_TYPE Tester_PASSED OUTPUT FAILED FEATURE_TYPE Tester_FAILED' is incorrect.  TEST must look like: TEST <value> <operator> <value> [ENCODED]
I know that there have been some changes with the encoding in FME and that there are some limitations regarding the operating system.
So we're running FME on a Windows Server 2016 (no service pack)
Do I have to apply some settings or what could be the reason for this error?
Thanks
Vera
vki
  • Jul 11, 2022 2:06 PM UTC
geomancer
Forum|alt.badge.img+71
  • Jul 11, 2022 2:28 PM UTC
So how did you set up your Tester? Like this? This should work.
Tester_Parameters
vki
  • Jul 11, 2022 2:33 PM UTC
imageIt's not working...
geomancer
  • Jul 11, 2022 2:35 PM UTC
So can you share the contents of your Tester?
vki
  • Jul 11, 2022 2:36 PM UTC
geomancer
  • Jul 11, 2022 2:39 PM UTC
Hmmm, looks exactly the same to me. Sorry, wanted to be sure about that.
I fear I can't help you here, hopefully somebody else can shed some light.
panda
Forum|alt.badge.img+20
  • Jul 22, 2022 11:19 PM UTC
2022_1Seem to work for me as well. Only different would be Window Server environment?
Maybe you can upgrade the tester​, or configure a new one?
vki
  • Jul 25, 2022 5:47 AM UTC
We will update the Server to WindowsServer 2022 and try again then. Thanks.
