FME 2020: How to join the none intersecting lines?
  • Nov 8, 2021 7:57 PM UTC
  • 71 views
jamal
Forum|alt.badge.img+5
In the screenshot below, I wanted first to break at intersection and then to join the none intersecting lines. How this can be performed in FME to end up with 4 lines?
Clip_1075
Clip_1076
Best answer by jdh
After the intersector you can use a LineCombiner with the junctions set to ignore attribute values.
jdh
Forum|alt.badge.img+41
  • Nov 8, 2021 9:50 PM UTC
jamal
  • Nov 20, 2021 6:58 AM UTC
Thank you jdh for the help. Right, the intersector can break all the lines and the inecombiner can join lines at vertices
Clip_1159Clip_1158Clip_1160
Clip_1161
Clip_1162
