FME 2019.0 problems
  • Apr 15, 2019 8:24 AM UTC
  • 33 replies
  • 601 views
lifalin2016
Forum|alt.badge.img+42
Hi.
I just installed 2019.0 (build 19238), and tried to open an old workspace, which made it crash FME.
After some work, I narrowed it down to a replicable error, where I open a blank workspace, and just try to add the Tester transformer. This alone makes FME crash.
I tested whether my setting FME to use Python 2.7 was a factor, but it also fails with Python 3.7.
Please advise.
Forum|alt.badge.img+63
Can't reproduce that here, first thing I would try is re-installing and/or trying it on a different computer.
lifalin2016
  • Apr 15, 2019 8:30 AM UTC
It kinda defeats the purpose to install on a different computer, doesn't it ? ;-)
  • Apr 15, 2019 8:32 AM UTC
I was unable to reproduce the issue with build 19238 (Win64) on my PC.
Try re-installing FME. If that doesn't work, you'll probably have to contact Safe support.
It could help to narrow down where the problem is. Since @david_r and I were not able to reproduce it it's probably something related to your specific environment or computer.
lifalin2016
  • Apr 15, 2019 8:55 AM UTC
So I tried to install the 32 bit version too, and it shows the exact same symptoms. It's not even only related to the Tester transformer, the TestFilter transformer does the same thing. I sampled most of the transformers before and after these two in the alphabetically sorted list, and none crashed FME.
And here I changed nothing after installation before testing.
lifalin2016
  • Apr 15, 2019 8:58 AM UTC
It may very well be something on this computer, but FME needs to run on it, and I can only perform the install, and report the error. What else can I report? It's a Win10 x64 with Home Edition and 32 Gb RAM and lots of HDD.
Is there a way to generate some low level crash info feedback to Safe ?
  • Apr 15, 2019 9:13 AM UTC
Try the instructions here: https://knowledge.safe.com/articles/714/general-troubleshooting-gathering-system-informati.html
Eventually: https://knowledge.safe.com/articles/692/a-guide-to-interpreting-the-system-information-bat.html
lifalin2016
  • Apr 15, 2019 9:48 AM UTC
I tried to replace build 19238 with 19236 (RC), but it changed nothing :-(
lifalin2016
  • Apr 15, 2019 10:54 AM UTC
So I finally got something to work. I copy'n'paste'd all transformers to 2019 except for Tester's. I then replaced these with PythonCaller's that did the same testing. This worked.
But then it wouldn't load my custom Python based transformers, even though I switched the compatability to Python 2.7, and even though they're located in my shared folders. Only when I copied the transformer to the "Workspaces" (shared) folder would it find (and use) it.
And then the Data Inspector crashed, after Visual Preview crashed.
Hmmmmm.
xiaomengatsafe
Forum|alt.badge.img+11
Hi @lifalin2016, Sorry to see that you've been having some issues with FME 2019. Just curious, were you able to get this issue resolved yet? If you haven't yet done so, please follow the link david_r shared, and use the bat file provided to gather some system info, and send it to us through this form: https://www.safe.com/support/report-a-problem/. We will investigate this further.
lifalin2016
  • Apr 23, 2019 8:08 AM UTC
Alas no.
But I did encounter a similar error with a couple of other programs on the same machine, errors I haven't seen before. So it may be a Windows (update?) problem.
The machine is running on Windows 10 Home. Is that a problem ?
Cheers.
lifalin2016
  • Apr 23, 2019 2:11 PM UTC
Dug this error message out from the event log:
Navn på program med fejl: fmeworkbench.exe, version: 2019.7.36.19238, tidsstempel: 0x5c9d7fb3
Navn på modul med fejl: Qt5Core_fme.dll, version: 5.11.2.0, tidsstempel: 0x5bac0970
Undtagelseskode: 0xc0000005
Forskydning med fejl 0x00000000001e38b8
Proces-id 0xef0
Programmets starttidspunkt 0x01d4f9dd70b99208
Programsti: C:\\Program Files\\FME 2019\\fmeworkbench.exe
Modulsti: C:\\Program Files\\FME 2019\\Qt5Core_fme.dll
Rapport-id: 56253910-c0b1-4798-b643-3c1f31935626
Fuldt navn på program med fejl:
Relativt program-id for program med fejl:
Looks like my machine has a problem with Qt5Core_fme.dll. Are there some special requirements for this ?
lifalin2016
  • Apr 23, 2019 5:42 PM UTC
I've looked into the Windows Update angle, and it seems that what worked nicely before March 10 now fails. I can see that multiple updates of Windows 10 version 1803 has been installed since then. What versions of Windows 10 has FME 2019.0 been tested against ?
lifalin2016
  • Apr 24, 2019 9:24 AM UTC
What is your Windows 10 version, if I may ask? I'm currently looking into whether it's the 1803 update that's messing up my computer.
lifalin2016
xiaomengatsafe
Hi @lifalin2016,
I did see another user experiencing crashes on a Windows 10 1803, as well. But I can't say for sure if that's just a coincident, that you are both on 1803.
I'm currently using Windows 10 Pro 1809. And I can not reproduce either of the crashes reported by you, or the other user.
If possible, I'd suggest that you try a Windows update, and see if that solves the problem?
  • May 10, 2019 3:26 PM UTC
I have the same problem as @lifalin2016, same behaviour and error message on in the event viewer - though I'm using the FME workbench bundled with ArcGIS the Data Interoperability extension.
In this case it's FME version 2018.7.35 Build 18568.  Windows 10 x64 build 1803.
Have reported through ESRI support (as they manage support issues with the extension) but thought I'd add mention that I'm seeing the same behaviour here.
Faulting application name: fmeworkbench.exe, version: 2018.7.35.18568, time stamp: 0x5be5204f
Faulting module name: Qt5Core_fme.dll, version: 5.9.2.0, time stamp: 0x59da53d2
Exception code: 0xc0000005
Fault offset: 0x0006cce8
Faulting process id: 0x2a44
Faulting application start time: 0x01d50739f98ca8e9
Faulting application path: C:\Program Files (x86)\Esri\Data Interoperability (x86)\fmeworkbench.exe
Faulting module path: C:\Program Files (x86)\Esri\Data Interoperability (x86)\Qt5Core_fme.dll
lifalin2016
  • May 12, 2019 10:23 AM UTC
It seems my second computer, which fails to run FME 2019, is a slightly newer build compared to my office computer, that runs FME 2019 just fine. Both run Win 10 version 1803, but builds 17134.706 and 17134.285 resp.
lifalin2016
  • May 12, 2019 10:26 AM UTC
And I tried to install the 32 bit version, but it also fails, mentioning "fmeprompter.dll" instead of "Qt5Core_fme.dll" as in the 64 bit version.
lifalin2016
  • May 12, 2019 10:47 AM UTC
I suddenly also had problems with Adobe Illustrator and Garmin Express. Reinstalling Express solved that, and using the 32 bit version of AI instead of the 64 bit worked (save to web). In the event of Express, that error suggested something related to Qt as well.
As for FME crashing, Windows made a couple of AppCrash files, so I'm attaching those here (one for 32 and one for 64 bit).
FME_2019_AppCrashes_20190512.zip
lifalin2016
  • May 12, 2019 10:59 AM UTC
The way I'm testing it, is starting Workbench, open a new workspace, and try to add a Tester. This crashes FME the same way every time. I just tried to add a TestFilter instead, and now it crashes with a reference to qt_workbench.dll". I do have QGIS 3.4.6 x64 installed as well on the machine, which uses Qt5 extensively, and it doesn't crash.
andreaatsafe
Forum|alt.badge.img+17
Hi @lifalin2016, are you able to install and try the latest FME 2019.1 beta? Do you still have the same behaviour?
We would like to see if we can resolve the issue in an upcoming FME 2019.0.x release. If you can submit a problem report here, quoting this forum post, we can set up a screenshare with our developer to gather further information.
- Andrea
sondickerson
I have the same problem with FME desktop 2019 installation. Only I can't even get the workbench application to start without giving an error. I uninstalled 2017 version and installed 2019. Other installs of 2019 worked on my personal computer.
FME Workbench has stopped working
Problem event: APPCRASH
Fault module: qt5network_fme.dll
Windows server 2012 R2 64 bit
andreaatsafe
Hi @sondickerson,
Sorry to hear that you're encountering this issue. We have had another user report this to us (same faulting module: qt5network_fme.dll) and we were able to find the issue and resolve it, it is related to the underlying framework FME uses for the GUI (Qt).
Are you able to install and try the latest FME 2019.1 beta? You can install this into a separate directory to test it out. If that works, we have also put the fix into the next FME 2019.0.x which should also resolve this issue.
Please let me know if FME 2019.1 beta has the same behaviour or not.
- Andrea
sondickerson
Hi @sondickerson,
- Andrea
I had an online chat session with Debbi and she mentioned the same thing. Yes, the beta version (b19570) did work. So that should keep us til the official version gets released. Thanks very much.
