Fix a flotaing view
  • Dec 24, 2019 9:55 AM UTC
  • 5 replies
  • 239 views
hanskoudijs
For some reason my "Translation log" view is floating instead of fixed. Don't know how to "fix" it again (FME2018).
Best answer by bwn
Then fall back solution is to reset the layout back to default. The solution involves resetting/deleting the relevant Windows registry keys as described in this post with similar circumstances:
https://knowledge.safe.com/questions/85059/restore-translation-log-window.html
Forum|alt.badge.img+63
If you drag it around you should be able to dock it, you'll see the panel behind it turn blue if it finds a target.
bwn
Forum|alt.badge.img+26
  • Dec 24, 2019 10:19 AM UTC
FME like a lot of different software uses dockable and stackable window panes.
If you hold and drag on the pane Title Bar, and drag it onto the edge of the FME window, you should get an outline of where it will dock onto one of the window edges.
This video is from Revit, so not quite FME, but same basic concepts shown in 2 minutes:
https://www.youtube.com/watch?v=DleiMs0n9Mk
hanskoudijs
  • Dec 24, 2019 10:35 AM UTC
Tried this but without succes.
bwn
  • Dec 24, 2019 11:27 AM UTC
hanskoudijs
  • Dec 24, 2019 12:10 PM UTC
This did the job! Thanks for the tip.
